How do a move a video a half of a frame on the timeline?
LampoFilm
Trying to line up videos from 2 different cameras. The audio is off a half a frame. I remember reading a few months how to do it, but I forgot now.
Thanks for your help.
edit the audio in an audio editor, slice half a frame's duration off the front.
in 24p half a frame is 1/48th of a second
I know how to move the audio half a frame in FCP but not in vegas.
Its impossible to move video half a frame in any editor unless the video was recorded at double the frame rate of the timeline
I can't find out the way I used to do it, so what I did find is if I turn off "Quantize to Frames" that I can have full control. Just need to remember to turn it back on after this project.
You can move anything -- audio or video -- half a frame or any other fraction of a frame by going under options and disabling "Quantize to Frames."
Audio, by the way, from Vegas 10 on is automatically NOT quantized to frames.
Just be careful with this -- it's easy to get everything on the timeline messed up, especially if you're combining it with ripple edits.
EDIT: I see you mentioned "Quantize to Frames" while I was typing. Yes, that's how you do it. :)
As David said, be very careful with this tool as it's very easy to mess things up big time if you're not careful.
If you need it, disable it, do your changes and enable it immediately.
Here's what happened to one user on the Sony Vegas forum.
Having that Off by mistake caused me much grief.
Really bad outcomes with mixed progressive and interlaced footage.
The "P" ended up a juddery mess, half my cuts blinked and even the interlaced footage in parts was a bit juddery.
Not so obvious on the LCD monitors while editing but once burned to DVD and played back on a CRT TV, yuck.
Mike
If anyone does find the short cut to move a video a half a frame, let me know. Does the new Vegas have this option?
I would use it a lot, because video from my canon and panasonic is always a half a frame off.
Video is meant to be cut/trimmed/moved in whole frame increments, never a partial frame.
You can use the Quantize to Frames option to do this but, for the reasons I outlined above, it's NOT recommended as you WILL (not can, WILL) mess things up.
If the video from your two cameras is, as you say, always half a frame off, then you need to find out why and fix the problem.
Mike
