How can I get rid of these lines?
HeyAndy
I'm using a trial version of after effects cs5.5 and I've installed the cc particles world effect onto it. But when I'm on the program these blue wireframes take up the composition.
http://
When I export the sequence they still appear.
I was wondering if anyone might know how I can disable them so that they won't show up in the final video?
Thanks.
I don't think you can get rid of them if it's a trial verison...they do that so you buy it.
That's correct... Nevertheless, if you still want to get rid of the lines I suppose you can purchase a previous version of After Effects (which of course would be cheaper), import your clips and use either the clone stamp tool or wire removal effect within the older version. You can then re-render your clips but even that wouldn't warrant perfect results... It would obviously be a tedious extra step you would have to take but this way you could at least take advantage of all the effects the newer version of AE has to offer. Not an ideal solution, although, this would get rid of those lines.-B
If he purchased an older version of After Effects, then he would have the plugin without the restrictions. No need to go through all of that trouble.
haha right! I guess since I read this post yesterday and replied on my phone today I didn't bother to refresh my memory with the details. He wants to access cc particle world not a new version of AE.
Good catch. In that case, disregard the workaround... That would be a hefty amount of trouble for no particular reason...
