How can 4:3 end up 16:9?
I know my DVX100 comes with a wide angle lens stock from the factory. I also know that if I want a wider view and to blow my footage up to a larger size that I should use a Anamorphic lens which I do not have nor used yet.
I shot some footage at an event over the summer and I edited it in FCP4. I then burned a DVD and everything is fine. The question that I have is that, I played my DVD on a portable DVD player with a flip up 7 inch wide screen. My project looks as if it was shot in 16:9. I didn't really notice it until I showed my work to a professional Avid editor at my job and he asked how did I get it to fit the wide angle screen. Again, everything looks really good and I have recieved very good comments about my project but I was just curious how I could go from 4:3 to 16:9 and I didn't adjust anything in FCP to output it to a widescreen format.
Re: How can 4:3 end up 16:9?
Well I have a Flat screen TV here at home and it looks the same way on there as it does on my portable dvd player.
Two things are happening, either the portable player and the flat screen are cropping your image to 16:9, or stretching it out to it.
You ought to be able to tell.
-CJ
www.arkhamfilms.com
Odds are, if it looks stretched, then a setting on either of the screens themselves (both the flat TV or the portable DVD) are on a 16:9 setting which is what's giving your 4:3 footage the squeezed look. You'd know if you shot originally in 16:9 if you had the wide screen aspect ratio and it did not look squeezed.
