Hmm.........
Pookie
Push up that nose of yours to create the perfect profile with this handy Beauty Lift High Nose, a beauty gadget that applies gentle electric vibrations from the bottom, side and front. Just slip it on and turn on the switch on the front of the frame.
While the supports hold your nose in place the buzzing will help shape your nose into just that little bit firmer and higher. All you need is three minutes once a day and you (and everyone else) will soon notice the difference!
The Beauty Lift High Nose features:
Recommended use time: 3 minutes per day
Size: 7 x 5 x 7cm (2.8 x 2 x 2.8")
Materials: ABS, silicone, steel
Power: lithium CR203 battery (included)
Weight: about 25g
Made in Japan
Only $144.95 US
