While this may not be a specific enough question to warrent specific answers. I am wondering what wattage of hmi is need to compete with the sun, for example to light a subject a stop or two above a sky. What would it take to darken the sky in this way during midday?
An alternative to lighting the subject - if you could find a way to compose your shot so the subject doesn't come in line with the sky, you could use an ND grad filter...
A 1k tungsten will show up on your subject, especially on an overcast day, but the color will be wrong, and once you gel it blue it'll be effectively a 250watt light, which will be of limited use in daylight.
For directional hard light you can probably get the effect you want with a 1200 HMI. If you want to run it through a softbox or other diffusion, that's when you start getting in the realm of 4k's and 12k's...
You can always multiple reflectors or perhaps even a few mirrors focused into one silk will bring you inexpensively to what you want - a stop or two over even the sun.
