I recently added a 1200w HMI Sirio Fresnel and LTM 575/1200w Electronic Ballast to my light kit. Recently as in I paid for it two weeks ago, shipping got delayed, it showed up a couple hours ago and I have a shoot tomorrow.
And as you might have guessed from the subject line of this post, it didn't produce any light.
I have limited HMI experience, but here's what I know:
- When all connected and plugged in, the ballast lights up when turned on and when I hit ignite the fans start in the ballast.
- When all connected and I press ignite from the head the fans on the ballast also turn on and the green light on the head's ignite button goes on (though dimly, but I think that's just the bulb they use there).
- The bulb itself was said to be new, though I assumed it was tested. When I took it out of its package it stuck a little to the plastic (maybe nothing) and I noticed there were little specks in the main sphere of the bulb (probably also nothing?)
- I inserted the bulb nipple out and tightened it down (never once touching the quartz). I did notice that the mount for the bulb isn't firmly mounted, as in it rattles a bit. Not sure if that matters.
And now I'm going to admit something very stupid... I wanted to check the connections on the bulb to see if they were tight, so I opened up the fresnel and went to touch the metal.... whilst forgetting that the ballast was still on. Got a little bit of a buzz. Not very much, but I guess from this I know that some electricity is going to the bulb. And yes, I will be smarter in the future about that.
So can anyone out there please offer any suggestions? Is this a burnt out bulb? Can I do anything else to test for this? I messaged the eBay seller, but they're a business down in LA and won't be back until Monday.
Thanks for any and all help!
