F fotoman Active member May 16, 2011 #1 I was thinking of getting a nanoflash to use with the 150. Has anyone had any experience with this combo? Also does anyone know what the bitrate would be of the 422 signal out of the hdmi port? thanks, John
S surfrx Member May 16, 2011 #2 150 and nanoflash 150 and nanoflash to answer your question I beleive it would be 8 bit 422 as the 150 is AVCHD AVCHD is 1920-1080 8 bit 4.2.0 if you looked into the what the spec's are for the AVCHD codec that would shed some light on the subject but I am sure I have seen this information elsewhere on this forum. I may be confused with your question you may need to check what the external recorder bitrate would be I beleive depending on your choice of recording codec you can choose 50mps -280 mps between the XDCAM Codec or the I frame Codec and of coarse whatever codec you choose will help determine the bitrate you want for quality and record time reasons. I have not used or had the opportunity to use one of those lovely devices I only am aware of this as I have done similar research. Last edited: May 16, 2011
