BobDiaz
The Professor
The Other World Computing (OWC) Mercury On-the-Go High Speed Portable Storage Solution is an attractive acrylic enclosure containing an Hitachi Travelstar 2.5-inch hard disk in capacities from 40GB to 160GB. If that's not enough disk space enough for you, the company offers the case and electronics only ($75), letting you provide your own 2.5-inch hard disk up to 500GB. For my evaluation, I used the 100GB FireWire 800/USB 2.0 model ($290). I took the unit out on the road and also onto our test bench, trying out both the FireWire 800 and USB 2.0 interfaces.
This OWC drive is quite small -- it's just 3.5 inches wide by 5.5 inches deep by 1 inch high. Even though the company says it weighs 11 ounces, I placed it on our scales and it actually weighs less than that, 9.6 ounces. Well, what you know, a vendor who's actually honest with the specifications, and understating them to boot.
Looking at the bottom of the drive you can clearly see the top of the disk drive, and it's a very small device indeed especially given that it holds 100GB. The Hitachi Travelstar included in this enclosure is a 7200RPM drive with an 8MB data cache. If you're using a recent Mac, you'll be happy to see the two FireWire 800 ports on the back of the drive. There's also a USB 2.0 port back there if you don't have a FireWire 800 port available. If you're a PC user, you can also use FireWire 800, but you have to get a PCI card that's installed inside your computer in order to use it. Since we already have a workstation with that FireWire 800 PCI card installed, I was ready to plug in the drive.
To read the whole review, please see:
http://desktops.consumerelectronicsnet.com/articles/viewarticle.jsp?id=38605
Untill someone test this, I can't say how well it would work with the HVX-200, but it does look interesting. A Firewire 800 write speed of 34MB per second translates to 272Mb per second and a USB 2.0 write speed of 13MB per second translates to 104Mb per second.
Given the price, $290 for 100 GB, it would not be unreasonable to have two units to backup your P2 data.
Bob Diaz
