fpinho Member Dec 13, 2005 #1 Hi, I made 2 diferent projects in vegas, both with PAL DV Template. But now, when i insert a vegas file into the other, appears two lateral letterbox in the inserted file. can you help me?
DBoz699 Veteran Dec 13, 2005 #2 Lateral? is it on the top or sides? did you shoot widescreen? What are your full project settings?
fpinho Member Dec 13, 2005 #3 I think i find the problem. On project is in PAL DV Wide and the other in PAL DV. thanks Fernando
