First a very basic question: roughly what level should the sound bars on the LCD peak at for interview recording? Should the bars run all the way up to just below the red indicator or less?
Another less stupid question I have is about the Audio Techica AT897 that seems to produce a much warmer and more vibrant sound on the EX1 than the Sennheiser MKE300 that I have connected to the EX1 via a Rode XLR adapter that I assume makes no difference to the recording quality? Am I right the AT897 is a better mic in terms of audio quality than the MKE300?
What surprises me is the AT897 shotgun also seems to produce better results when used on a stand close to the speaker for interview recording than my old SonyECM959A (also connected with the Rode XLR adapter) that as far as I understand is designed for voice recording? Furthermore, I have to boost the camcorder audio input trim setting to -59 to get useable audio levels from the Sony ECM959A. Maybe because the Sony ECM959 is an older mic that was not designed to work with this type of camcorder?
So final question, would you reckon the AT897 could be used both as an on-camera shotgun for run and gun and also on stand at a distance of about 2 feet/40cm from the speaker for interviews. Or is this the audio equivalent of trying to use a rifle as a cigarette lighter?
