DELTA_Rotary
I've got a Marshall V-R84DP-2C monitor that has BNC connectors as inputs. Currently I'm just running a RCA cable from my HVX-200 into the monitor using an RCA/BNC adapter. The monitor works fine if its SD footage but if I shoot HD forget about setting your focus. I know its not the best monitor for the job and its resolution is only 800x600 but I was hoping there was an alternative that would allow me to feed the monitor a higher quality signal using the cameras component output. Any suggestions?
