help with canon lens
cheezweezl
when using my 35 adapter i can't change my aperture setting. it stays wide open all the time. i understand this is a common problem with canon fd lenses due to the design. does anyone know a way to fix this?
I have asked if the theory of changing aperture settings in CANON EOS lenses using a CANON still camera and then putting the lens back to the adapter is valid bat never got a posittive answer from someone that actually did it in reality. Is this the way you did it ?
piece of toothpick jammed in the spring loaded switch on the back of the lens to keep it open did it. now my aperture ring works on the adapter.
