S seanwin Active member Aug 8, 2011 #1 Hi I opened Vegas Pro 10 to make some changing to a wedding edit. All the files are in the right folders, but Vegas is selecting the wrong fils o everything is all over the place. How can I rectify this, is it something changed in the properties?
S seanwin Active member Aug 11, 2011 #3 Yes I did keeps happening, the file in the timeline is the right filename. but its replacing it with different file names. I had a previous export of clips so I was able to use that, but for a lot of it I ended up replacing the clips.
