blazingoat
Carbonite Member
I'm trying to figure out how to setup my SD MixPre to work the DVX100A. When I've used this mixer with a PD150 before, I had to use Pads. Do I need to use them with the DVX?
Should I set the DVX input to mic and use a pad between the mixer and the cam, or set the cam input to line and not use the pad... Both seem to sound fine.
Also should I use -50 or -60 in the menu?
I'm sooo confused.. I Really don't understand audio that well. I thought that there are two different types of line level signals -10 and +4... and that the mixpre puts out a +4 (profesional line level) and that the DVX has a -10 (consumer line level) Is this correct?!?
Does the DVX line level accept the professional line level wheras the PD150 doesnt?
THANKS!
THANKS!
