Hi All,
I'm trying to use some Filter effects on an audio clip and can't seem to get the audio to play in real time while I make adjustments. Here's what is happening:
(1) I double-click the audio clip and it opens up in the Viewer
(2) I click the Filters tab, then select a filter - let's say the Parametric EQ
(3) As soon as the Filter opens, the "Needs Render" red line appears above the clip, and when I try to play the clip back while making adjustments, all I hear are beeps.
Is there a setting somewhere that I need to change to allow me to make filter changes and hear the results in real time?
Thanks!
Mark
Thanks!
Mark
