Help - terrible interlacing artifacts
taormina
Hates to Rent
Hi Guys...
watch the following clip - about 24 mb.
Shot on HVX, 1080 24p. All setting in camera are the defaults. It was supposed to be a low light test. I edited it in Vegas.
FYI: Vegas edits all my 720pn stuff perfectly - never had a problem. I imported this .mxf using raylight. Vegas correctly identified this as 24p footage - so the properties box is correct. I changed the Deinterlace method to interpolate fields, but there is no difference between that setting and 'none'.
I'm pulling my hair out - this only happens in 1080 24p!!!!!!!!!!!!:furious3:
Link: www.taorminafilms.com\seb.wmv
taormina said:
Hi Guys...
Raylight can't remove pulldown from 1080/24PN, only 1080/24PA
When MVB says "1080/24pN", keep in mind there's not a camera setting that identifies that. It's actually the "1080/24P" mode.
