Help!! Squeeze? Anamorphic
keynstring
I'm looking at 2 separate projects in my FCP 5.1
Both shot in Squeeze.
One IS Anamorphic. Vertically Stretched.
On IS NOT. I want it to be like the other one.
All the Capture and Sequence settings look to be the same.
WHAT AM I MISSING?
BUMP
I know i'm missing something here. And....And.....I can't get the Vertically stretched film to render to a quicktime movie in the proper A.P.
K, i know i'm being moronic. Please throw me a lifeline.
If you're sure they both are anamorphic...
Find the clip that isn't showing up as anamorphic in FCP's browser window control-click it to bring up item properties.
That will open a window with lots of information... somewhere on there will be ANAMORPHIC... place a check in that column.
Then reload it into your viewer and timeline. Should be fine.
CaptM
Drop your anamorphic footage (that is flagged) into a 4:3 timeline (non-anamorphic).. it should add the appropriate boxes to the top and bottom of the frame and render out properly as most any quicktime file.
Otherwise most quicktime codec's don't have the flags to specify animorphic so thats why your footage rendered out to a quicktime movie don't have the correct aspect ratio, because it will send it out to a default 4:3 pixel aspect ratio file unless you specify otherwise in the "size" dialog box.
