Hi,
I purchased a URX-P03D dual-channel receiver, and two UTX-B03 transmitters separately. The URX firmware is 1.0. One of the UTX-B03 has firmware 1.05, the other 1.04. All three use channels 30-36 (566.125-607.875 mHz) and 38-41 (614.125-637.875 mHz).
However I'm unable to get the set-up to work. I have tried manually setting the channels to match but only get hiss in one channel.
Earlier on I was able to get the receiver to "auto scan" and detect the transmitters. But now even that doesn't seem to work.
I've just "reset" all three devices to no avail.
I'm just wondering what I should do to make sure I'm setting this right--or to know for sure that these devices aren't malfunctioning or broken.
I am using these in Beijing, China--I don't know if that makes a difference.
Thank you.
Thank you.
