vitaluminosa
[deleted by user]
overnighttolondon said:Post us a clip
What were you shooting this in? 60i? 24p? 24pa?
It sounds to me like a field problem, if you're sure there's no vertical shaking at normal speed. For viewing both normal and accelerated footage, it's important to make sure your preview window is set to 100% so you can see all of the fields.
Right-click the clip and play with the field options. Try reversing field order, or always deinterlacing. If you shot this 24p (not 24pa) you might be in a bit of trouble, I don't think that speeds up very well (because of the way it has to distribute across the 60i frames - you're better off using 24pa and working on a true 24fps timeline. One thing you can also do if you want slight slow motion is shoot 30p, export it as a still sequence, and reimported as 24p).
Anyway let us know if this helps
