HELP!!! p2 store no thumbnail on files!!
mLAne
I imported a few cards onto the p2 store and then moved them to an external HD via p2 genie. all of the files have no thumbnail and will not come in properly!! is there any way to repair this! if not I am in BIG trouble!!!!
when I rtry to imprt these files into FCP via p2 import they say error no data. The files are there and each partition is the right size, 7.? gigs
help!!!!
thanks in advance!!
Try repairing the clips using P2 Log. The absence of thumbnails shouldn't be a big deal as long as you have the MXF files, that's where most of the important information is.
I have the SAME problem. What can we do? Anything on the Mac side that is a utility for this. I still get the thumbnails but I can't import them.. says missing data. I am too screwed if I can't get this solved.
If you still have the footage on P2 storer then I will connect the P2 storer directly to Mac. Import in to FCP and then save it on HDD. If you want ot copy the cards there is a PC software called Store manager it automatically installed when you installed the driver for the P2 store on PC. This utility will tell you if there is a corruption in the footage.
