David W. Richardson
Chapelgrove Films
Here's the deal...
I've had Netflix working through my Blu-Ray player for a good while now, using a wired (not wireless) connection that runs through a Netgear wireless router (one of the wired ports), then to my cable modem.
All has been well for months.
But I've been bothered that I didn't have any security enabled on my wireless router. I think my neighbors may be piggybacking on me. So I was getting ready to setup an access list. To do that, I needed to logon to my router -- only it wouldn't let me. Said my password was invalid.
First thought I had was that my neighbor may have logged onto the wireless router and changed the admin password. So I pressed the reset button on the router. I was then able to logon with the default password, and change it. Got everything back up and running --
-- my PC, which connects to one of the 4 wired ports on the router. It connects to the Internet just fine.
-- all of the various wireless devices -- Nook Color, Netbooks, and laptops -- connect to the Internet.
But my Blu-Ray player won't connect for some reason. Wait....that's not entirely correct. It will connect using the WIRELESS, but not the WIRED connection. Which makes it very odd.
No cables were changed.
I considered the possibility that the wired port the blu-ray is using on the router might have gone bad, so I tested it. My PC connected to the same port works fine. The blu-ray connected to the port my PC was connected to still doesn't work.
So that seems to narrow things down considerably. I've tried re-setting up the blu-ray player's network connections. It tests the network and passes. But it doesn't seem to see the Internet, except via the wireless connection.
I don't want to use the wireless because of the distance between the blu-ray player and the router -- the connection is unreliable for this use. That's why I ran a cable the length of the house.
I've tried using automatic settings on the blu-ray. And I've tried manually setting it, using the IP address, default gateway, etc. that Windows IPCONFIG and the router settings software both show me. Nothing seems to work.
I've powered everything off, pulled the battery out of the cable modem, then powered everything back up in the appropriate order -- cable modem, then router, then device. But it still only works via the wireless connection.
Just yesterday I got the Netflix app installed on my Nook Color. For a brief moment I thought that might be part of the problem -- since supposedly Netflix limits the total number of devices it can be used on. But if that were the case, then it wouldn't work wirelessly through the blu-ray player either.
I've run out of ideas. Anybody else got some?
