HELP NEEDED! HPX170 + microMatteBox + microFollowFocus.
Greetings!
I'm looking for some help. I own the HPX170, and some time ago I got the microMatteBox. Everything was perfect, until I got the microFollowFocus V2. When I tried to use the 3 items together, a problem appeared, the focus ring of the HPX170 is too close, almost inside the microMatteBox. So I thought that a lens hood was needed. So far I have bought two, and both cause vignetting in my image, I have to set the zoom setting to Z16, no lower.
Has anobody encountered with this same problem? Have you any idea of a lens hood that does not cause vignetting if I need Z00?
Thanks for your patience and support!
