I've pressed all the buttons, twizzled the dials, and perused the forums, and now I need some guidance...
The inbuilt mic on my Canon XHa1 has come off, with the connecting wires snapping in half.
For a while I used my rode ntg-2 mic plugged into XLR channel 1 and it worked fine.
However the last time I used it the audio levels remained very low (barely audible).
Mic att switches are in the off position. Tried audio levels on auto and manual, makes no real difference adjusting levels.
I tried taking the battery out of the ntg-2 and switching on the +48 phantom power on the front of the camera.
This resulted in loads of white noise making the audio unusable.
Does anyone know a solution to this, or what's going on?
Does it sound like the camera's wiring is messed up?
If so, anyone know how/where to fix it?
The closest I got to ok audio was by going to the camera menu and selecting +12db in the audio options, with the phantom power turned off.
I'm a bit of a newbie at all this, but I've got a couple of projects coming up so I really need to get it sorted.
Thanks in advance, tom.
