bigbigblue
I am very new to Cinematography, and despite having Googled and read this (and other) forums for many hours, I am still totally confused as to which frame rate I should be using for my particular circumstances, so any help you can offer would be very much appreciated.
I am filming low flying jets, which absolutely requires me to commit the cardinal sin of cinematography - using fast pans. An example of the kind of thing I am filming can be found at http://www.youtube.com/watch?v=yyTts-CpvIQ
That footage was filmed in 1080i/60i mode on my Panasonic HPX-171E, however I am not sure if that is the best mode to use (as there is also a 720p/60p mode on the camera).
I am looking to release a DVD both in the UK and the US and potentially, if there is demand, a Blu-Ray disk of the same footage too.
1080i/60i was chosen initially as this gives reasonably stutter free footage even given the quick panning required, however because it is interlaced, the freeze frame and slow motion performance of the footage is poor, so I would LIKE to use 60p instead, which I presume will give me the smoothness needed AND allow decent freeze frame and slow motion performance.
Confusion reins however when it comes to considering conversion of 60p footage to DVD and Blu-Ray. In creating a DVD for example, I presume the conversion software (I use FCP) will simply drop every other frame, and I suspect I will get back to having a bad stutter in my footage. I know insufficient about Blu-Ray to know whether such a conversion is required.
So, anyway, my question is whether I should stick with 1080i/60i or switch to shooting 720p/60p, and whether (if the answer is to go with 60p) I will be able to get smooth footage on DVD and Blu-Ray from it.
