Help !!! I upgraded to Vegas pro 12 and tried out Color Match, but ...
kwkeirstead
I see the source, I see the target, I do get to see the corrected/improved brightness, BUT it does not show up in the viewer. Is there some parameter I may have inadvertently changed that does not allow dynamic updating of edits at the viewer? I am checking now to see if the Color Match edits actually find their way to rendered files.
Looks like the mods apply to the entire video, not just the clip you reference as the target. You only get to see the result following rendering, the plug in does not seem to update the viewer.
Check above the preview window -- is the button with the circle inside the square clicked? If it is, unclick it.
