Help, I have run out of ideas. I’m a new convert to Adobe Premier Pro 5.5 from
Final Cut Pro 7. I have a MacPro, 32GB ram, Snow Leopard, everything up to date.
Yesterday I worked on a tutorial from Linda.com, downloaded the work files, everything
worked great, life is good. Today I started Premier Pro, dropped a clip into the timeline,
hit the space bar to play...nothing happened! OK tried another clip, still nothing.
I Imported some P2 footage that I had been working on in FCP, still nothing. Even tried
some still jpeg pictures, nothing. I can scrub without any problem. I can use the jog wheel
without any problem. I can use the shuttle without any problem. I can use the arrows
forward and reverse without any problem. Anytime I try to play a clip, either in
the timeline or the source window, it will not work. I have tried using the space bar,
the “play triangle”, the “J” “K” “L” keys but no luck. I reinstalled Premier Pro and that
did not help. I am sure I have done something stupid, but I have run out of ideas.
Does anyone have a suggestion?
