Help HVX200 wont power on!
DELTA_Rotary
Ok I did a small shoot yesterday here in the studio. Took the tape out to capture the footage in the FCP. I went to leave a couple hours later and I noticed that the tape door was open. I went to power the camera on to close it and it wouldnt power on. I figured the Anton Bauer Elipz battery was dead so I put them on charge overnight. I came in this morning and it still wont work. I tried another battery and even plugged it into the wall outlet directly still nothing. Any ideas? I'm starting to fear the worst.
Try a System Reset (pg 126 0f the manual).
Also, you should know that it is not necessary to turn on the camera to change tapes. Just need to have a battery or power installed.
Well its definetly not getting power then. Panasonic just told me to ship it back to them and they would fix it. :( They said its more than likely an internal fuse.
Turns out it was a blown internal fuse. Shipped it to Panasonic and they fixed it and go it back to me in a week no charge. While I hate to have the camera break the service from Panasonic was very good.
Hi,
The early release of Elipz battery and connector have the potential to cause this blown fuse. Be very clear about lining up the pins with the holes they go in because if you have the connector reversed and try to make contact you may cause this problem. If you look at the holes on the battery the metal connectors are right out at the edge and the pins on the connector are just a little longer than the connector shell. These can make inadvertent contact and there you go, dead fuse again. You can contact Anton and they can rework the battery connections for you so this never happens. I would recommend doing this.
Hope this helps,
Jan
