help. how can i get this look on vegas?
phazelee
i have a question, how would i get this color effect on vegas? i did this in photoshop, by using an action i downloaded off of a website. it sort of gives it a green-ish look but still maintaining the color.
here is a before and after.
There are a number of ways you can attack this.
You could try the Color Corrector. Lower the Offset a little bit to compress the black levels. In the highlights wheel, move the dot toward green/yellow.
You could try Color Curves. First, flatten out the lower left of the RGB curve a little bit. Then, select green only and raise the highlight some. Select blue and lower the highlight some, but not as much.
Adjust to taste. It might not get you exactly there, but it's the direction you want to go in.
There are other ways, too. Vegas tends to have several different ways of doign things.
