henryfinlay
So I'm just getting into FCP and editing in general. I have very limited knowledge, and I think I'm learning it well. I need to start on a project, so I'd like to get some help before I start.
So I have 3 types of footage:
HVX200 (1080/30p, 1280x1080, DVCPRO HD, P2 cards)
JVC Everrio (1080/30p, 1920x1080)
GoPro (1080/30p, 1920x1080)
Finished product:
It just needs to go on Youtube. The best I can get on Youtube.
So from what I've learned so far, here's what I think the workflow is:
1. Log and transfer everything from the HVX and GoPro in directly.
2. JVC Evverio has to go through MPEG-Streamclip because it is not meant for Mac's. (what should I export it out of mpeg-streamclip as.... apple pro res? h264? apple hdv?)
3. In FCP, create a project and change the Sequence settings: Frame size: 1920x1080, Pixel Aspect Ratio: Square, Compressor: Apple Pro Res 422 (HQ)
4. Start editing. When I drag the clips into the timeline and it asks "Change sequence settings to match the clip settings?", I should say No? (I was told to do this because I have different types of footage, and this will make them all match)
5. Do all the editing and what not.
6. Export it: Compression: H.264, Dimensions: 1920x1080.
So that's what I think I should be doing. I heard I should be using Apple Pro Res 422 (HQ) because it makes for faster editing, but doesn't diminish quality?
Is there something wrong with my workflow? What am I doing right or wrong? Thank you for the help.
Finished product:
