andybiz_2005
Hi all,
I need some help regarding something. I recently shot a wedding with my DVX with the "letterbox" setting in which the aspect ratio is 16:9 & both the top & bottom of the screen is blacked out. My wedding client requested that I do this so that it looks more like watching a movie.
OK, then I uploaded the footage into Premiere Pro 1.5 using the following setting : "DV-PAL Widescreen 48KHz", Pixel aspect ratio of 16:9 (1.422).
After editing the entire wedding, I test burned it on a DVD to see the result. After burning, I played it back from my PC's 4:3 aspect ratio LCD monitor & it looked fine (black bars on top & bottom of monitor & 16:9 aspect ratio)
Then I tested the same DVD I burned on my DVD player & viewed it from a normal 4:3 CRT TV. However, when I played it from my CRT TV, some parts of the left & right hand side of the footage was cut off to fit the 4:3 aspect ratio of the TV & there were no black bars on top & below of the movie.
I want to know if I made a mistake when I selected 16:9 aspect ratio in Premiere when I first opened this project. Should I have selected 4:3 aspect ratio in Premiere instead? Since my timeline is already set in the 16:9 aspect ratio & my video is fully edited, can I changed the existing timeline to 4:3, or do I have to edit the entire wedding all over again in 4:3 aspect ratio? Please help as I don't know what to do. Thanks.
Andrew
Andrew
