Here is my problem. I have encoded a 40 min video mpeg-2 with Compressor 1.2.1 and when I only encode a short clip of the video the "pixelation" I am seeing goes away. When I encode the entire video a strange pixel-shift-effect happens in some of the shots. For instance, the image looks smooth but the pixels in areas shift back and forth giving a kind of repetitive pattern effect. Again, if you look close at the image you can see clusters of pixels shifting from one spot to the other and back again! Weird.
I use 60 High Quality Encode and leave all the presets alone. I believe the presets leave the bitrate at max 7.5 and Best motion etc. I also use 2-pass encoding...
If anyone can help I'd appreciate it, this thing needs to get sent off today Fedex!
