Help: Can't hear audio without render
Antoine_Fabi
Hi,
I'm new to After Effects CS3.
I can't figure how to hear the audio even once i made a preview in the timeline.
(The audio is activated at the left of the audio layer)
The only way i can hear audio is by using Composition/Preview/Audio Preview
...but then, no image movement...
What am i doing wrong?
thanks!
The "zero" key will toggle the RAM preview so it will render when you hit it once, then playback when you hit it again. If you you let it buffer up a while and then let it play, you'll hear the audio...
