HELP: After Effects is exporting wrong sized frames.
DecadenceFilms
Hello Gents,
Got a little workflow problem.
I've exported a file from Premiere Pro, originally GH4 footage, using media export and H.264 compression. All is fine.
I've imported said file into After Effects to do some stabilisation. All went well. Frame size in the composition matches original. Stabilisation all fine and dandy.
Add to render queue. Try to export as a quicktime using h.264 (I figured I could live with the compression for the benefits of watching it jerk free) but despite the settings showing the frame size as matching the original...3840 x 2000 and odd....the file comes out as a 2000 x 2000. I've tried it a couple of times with the same results. What am I doing wrong?
Cheers.
