Help!!! 25p projects doesnt open!
Tom_Borg
I had to format my disk and made a backup of 3 projects: 2 in 25p and one in interlaced. the one in interlaced opens without problem but
when opening the 25P projects a message with porcentage change, trying to open:
filesystem busy, retrying (opening doamin on s...
10%, ,25% ..
and just before the 100% this terrible mesage come up:
ReadDomainWithMobs: failure opening domain on stream for bin
Raise Error
or
Try some more
and then:
a serious program error has occured:
Restarting th computer is recommende:
If you need further assistance record the following information and call Avid Customer Support:
Error: Assertion failed: aDomain
File: T: \ppg\MediaComposer\Media_Composer\MobReaderUtils.c, Line:359
I dont know if this has to do with that those projects are on 25. Maybe not. But I am desperate!!! i donw want to loose those 2 projects! The files are ther..i mena the bins and the project files. Maybe something worng happend under the backup proecess.
Any comment on how to recover some of the lost! (the files are there!!!! so i dont wnat to say tehy are lost)
help!!!
Michaelp?
thanks
tom
I tried to open from the backup disc and then to cpie to the brand new formated disk. But its the same on both.
Re: Help!!! 25p projects doesnt open!
did you ever figure out the answer to this problem? i'm going thru similar issues. thx.
Hi guys!
Thanks Michael P, but i managed to find out what happened Not good news at least for me but maybe Todd coud have more luck: Todd i recommend you oppen your project, bin files in a hex editor. If they are corrupted as mine are it wull only show 00000000000000000000000
000000000000000000000 and so on...
It seems that i had bad luck when doing the backup and they were corrupted. I will have to do the pojects again but its much better now that i will assume the right security workflow and test backuped files before a format the source disk. Taht should be also my recommendation for anybody that has gone for the same problem.
Todd, if you have not formated the source disk look for previous older file in the Attic folder that is inte the Avid xprees pro folder. This folder contains older versions of the bins. At least you ought not to have to create the whole project form scratch i had to.
//greetings Tom
