Postmaster
Dark Side of the Camera
Darren was asking me this:
I wanted to write a step-by-step article about that in my blog, but gonna answer it first here.
The wider the lens, the sooner you get the cross hatch vignetting, because it crawls in from the sides.
Actually I found an easy fix for that.
The Heliopan has a little screw on the side, that not only acts as a stop, but also holds the front glass in position.
1. Take your widest lens, and put the Heliopan on it. Point the camera to the sky.
2. Turn the ND to the max, till it hits the stop (you probably already see the vignetting coming in)
3. Loosen the screw just enough, so that you can twist the front glass.
4. Dial the glass back till the vignetting is gone - make sure the outer ring stays at maximum.
5. Fasten the screw.
6. Wipe off your greasy fingerprints.
Done.
Frank
Hey Frank, I have a question . My Heliopan has the cross hatch vignette when at MAX ND on wide lenses eg. 17mm . When at 17mm properly exposed shots in full sunlight outside has some vignetting at the corners (not max ND ,because max ND as stated yields the cross hatch "X" which disappears only at 35mm and above). However when zoomed in to about 24mm the vignetting goes away for a properly exposed image in sunlight.
My question to you is does your wide lenses preferable 17mm (or in that region) exhibit these things? I've been using my Heliopan for some months now and only just realized this some weeks ago. So its something that can be missed. Another fellow dvxuser said his had the cross hatch and he exchanged it and the replacement doesn't have it. But i'm not sure what focal length he tested it at (cant get a response from him as yet). I'm weighing whether to send mine back for a replacement.
Done.
Frank
