So I'm having a little trouble with my HDV workflow. I'm producing mostly for the web(or I should say to be viewed on the computer at times off line), and a lot of the footage has chromakeying involved. This is one of the main reasons I thought HDV would be better than SD because HDV is easier/cleaner to key than SD. I know that computers are progressive and square pixels. So I should record in 30P? Then capture the HDV footage into my NLE, then make my rough cuts and export (in an uncompressed format to After Effects for the keying and titles,ect..), then again export out of After Effects back into my NLE for the final cut, then export out again (in an uncompressed format) to Sorenson Squeeze and ......what? I feel like I'm making some major mistakes here.
- should I convert to SD in the camera before capturing? (would that make it more difficult to key?)
-when should I change to square pixels? (in the NLE on the rough cut?)
-what formats should I be using to go from program to program?
-are there any advantages in using HDVSplit?
-how should I deal with the Pixel Aspect ratio's and the Aspect Ratio's for web based video
I tried to research a bunch of old posts but still a bit confused, as always much appreciation for any replies.
