FW=Firewire
In the camera itself you can change whether or not HDV or DV is coming out of the FW port. The manual should have instructions on how to locate and change the setting.How do I set it so that the fire is set for HDV because I looked at my firewire plug and its pluuged in and it says HDV/DV
the XH A1 HDV 24F is exactly 23.98 frames per second, no pulldown is involved.Have you tried using the HDV 1080i60 preset? I haven't used the XH-A1 but most HDV cameras capture 24p in a 60i stream. Is the FW output on the camera set for HDV or DV?
-A
