HDV Edit IN Vegas SLOW!
  • Start date Start date
G
Guest
Guest
Hey guys, I have a quick question I just downloaded some clips from FX1 and I have two problems
1. all the videos play in Vegas are very slow, at 3~7 fps... and I have a very nice coputer AMD 3000 + 2 GB of Ram runing Vegas 5, XP Pro SP2, what should I do? I would like to move to HD but Do I need a new computer?
2. Lines run through the movie... There are lines run through the movie and is not smooth movie is something wrong with my computer or it is becasue FX1 is not running progressive frame
thank you for your help
jin
;D
Re: HDV Edit IN Vegas SLOW!
The suggested HD workflow in Vegas is to render your footage to AVI, then add the HD as takes so that anything you apply to the avi (color correction, etc) is also applied to the HD.
In other words, you create avi proxies for your HD footage so the system can process more quickly during the actual edit stage.
Gary
How to do Takes? in Vegas.... I try to read manual but I still have problem? please help
Right click/drag the media from the explorer and drop it on the timeline event. Choose 'add as take'.
Gary
I did that part, what does takes do in vegas I am new to this. After I make the changes to the AVI file how can I apply those changes to m2t or the HDV files? How to make the link?
thanx
jin
One more thing I just checked the AVI is larger than the M2T file and yet avi file are no delate and m2t. are very very jumpy?
why is that?
thanks for all the help
jin
With HDV, you *could* render to avi, but it will cost you space and a lot of time, and you lose color space, color correction on 4:1:1 isn't going to be accurate on 4:2:0 which is what HDV is. Not to mention the skewed aspect. (1.333)
So...for the time being, deal with slow. Or get the Cineform HD aspect tool, which does a different kind of proxy and works VERY well with transport stream conversion.
Editing HD just ain't ready for primetime, not today. Could very well change quite soon.
