HDR Timelapse!!
upshot
Been thinking about it for a while... Finally did it and what can I say! This is friggin' amazing. I wish I had the bandwidth to share this with you all in high def because the detail is mindblowing.
http://www.youtube.com/watch?v=0iLfqpIaKCs
UPDATE: here is a page linking to a 720p h264 quicktime... http://www.imapnet.com/jay/HDR.html ... don't know why it's choppy with this codec but at least it's small... smooth as butter in other codecs.
Matty_g said:
how big is the 1080 file?
Let me check on that... I only compiled the sequence 480i so far (it's 62mb mpeg2). Just did it yesterday! I'll compile 1080.
RE:panning
I'm using a telescope head with an RA clock motor drive at 4x for this one. Works like a charm!
what codec should I use? picvideo-mjpeg? mpeg-4? div-x?
I'm green on 1080... the orignials were 19--x12-- so I should be able to compile a high def...
Holy lord. I definately can not help out with that. I usually use h264.
if you get it down to around 100 megs let me know and i can help with some hosting.
I'll give that codec a try... I'm sure if I go to 720p it will help too...
woah! that's very cool... do you mind linking the "telescope head with an RA clock motor drive at 4x" you used? Thanks!
cody
