HDMI cables
ggrantly
Hello Listers,
Like many of you, I have an external monitor and in this case need to switch from using component I/O to HDMI I/O. There aren't too many choices for short HDMI cables, and the ones I have seen are all pretty stiff. Also, my cam and monitor both have full sized type A plugs; many of the shorter cables have one type A then a mini-HDMI for use on dslr cams.
Could anyone recommend a source for "super-soft" 18" HDMI cable with two type A plugs? This seems like it should be easy.
Grant
Thanks, I hadn't really thought of eBay. Checked bh and Markertek without much luck. I suppose I was being a bit lazy.
Grant
eBay's great for the HDMI cables. They're cheap and and they work great. I was surprised how expensive these things can be in the local stores.
