Barry_Green said:For the HVX, I don't see the point at all -- the HVX doesn't have HD-SDI output, so you'd have to use an additional $1500 component->HDSDI converter and then you'd get two minutes of storage for $6400 ($4,900 + $1,500).
Benton said:Barry
Are you suggesting that there is a way to get uncompressed HD (not DVC PRO HD)
out from this camera?
Yes, through the analog component video outputs.Benton said:Barry
Well, no, analog won't be exactly the same as HD-SDI of course. HD-SDI can take the direct digital stream right off the DSP, whereas with analog you have to convert that to analog, then capture and digitize that back to digital. HD-SDI will of course be cleaner.Benton said:But just the same as the Canon H1's SDI output
:laugh:Benton said:...Emmanual's Russian HDrive...
Benton said:BTW: Is it true the P2 only records good takes?
I have heard it will automatically detect .....bad acting and delete it on the spot, clearing up more space in the card
johnc said:Going to be a lot of empty P2 cards out there. :grin: :grin:
johnc
