Girbilcannon
Okay, so currently I am using a couple of UX180s, which obviously have the ability to sync timecode from an external source. However, I want a small "run-n-gun" type camera that can be handheld and free of all cables. For that I am looking at the HC-X2000 for its small formfactor and usual Panasonic setup. The problem I am concerned about but haven't found any answers for yet, is syncing cameras, using the HC-X2000 as the source as it has an SDI out terminal.
Now looking further through product user manuals for solutions, I found that the Deity TC-1 modules have the ability to jam sync from an external source when set as the master module. If this worked, I could then use the other modules on my other cameras.
Does anybody know if this would be compatible with the HC-X2000 from the SDI out terminal using the master jam sync option on the Deity TC-1?
If not possible that way, is there a small and simple way to rip the timecode from the HDMI out (assuming it carries) and split it to its own source?
