[NOTE: I'm going to paste this from the post I made on majorgeeks.com since I got directed here from them and it will be better for me to just do it that way. That and I'm just lazy. :engel017:]
This is happening with Vegas and Elements on my Vista machine. Movie Maker is, for some odd reason, unaffected. Not sure what's going on, and I've tried some information from the ONLY other board that had someone post with a similar problem, but nothing was solved (involved me having to take ownership of the System32 files, which was a chore on its own for the solution doing nothing to help it).
The issue is that it won't start up without crashing and giving me the "Sony Vegas has stopped working" (or Elements, in that case). On the Vegas thing (can't remember the Elements line that it hits before crashing), it crashes on the "Initializing DirectX Plugins" line on the startup (signs of a DirectX issue that could cause other programs to not function correctly, I figure). This also happened after I reinstalled it (I reinstalled it and it first started up fine, but crashed when I tried to feed it certain projects I had or feed projects certain files. Then I went to update it to the current version, and that's when I hit the exact same problem to get me to try reinstalling in the first place).
The site also linked to the Microsoft DirectX Dev Kit, which I have no CLUE how to use or what to do with it to even BEGIN troubleshooting this. I've been trying EVERYTHING (I cleaned out alot of viruses and worms), but to no avail.
