Have Premiere Pro CS3. Where is P2?
Michael Erlewine
I just upgraded to Premiere Pro CS3. I understand that I can now download full P2 file support, but where do I find that?
Soes someone have a link to where that upgrade file or service pack is?
Thanks,
Michael Erlewine
Heart Center Studios
open the program and under the help menu ( i think ) is an update programs option or something like that. You're looking for version 3.1
Thanks for the response. I checked that, but no updates were offered. I originaly did update something after installation, but I don't remember P2 being mentioned. What is a way to tell within Premiere if the update has been installed?
Thanks,
Michael Erlewine
Check the splash screen as the program is loading, or go to Help>About; you're looking for either version 3.1.0 or 3.1.1 for P2 support.
To import P2 clips, use your normal import procedure (File>Import, Ctrl+I, double-click in project window) and navigate to the VIDEO folder in your P2 folder structure. Select the VIDEO folder, and hit the "Import Folder" button; all video and audio clips will be imported. Conversely, you can navigate into the VIDEO folder and individually select clips to import; the audio will come with the ones you select.
