pmgmedia
I am backing up FCP footage from a 320gig G-RAID firewire to a 500GB myBook using USB 2.0 - here is my question: I have heard that USB 2.0 is not good for video editing because of the way it writes data onto the disk - this will not effect my backup files, though, correct? I may need to write the files back to a separate firewire drive before editing with them..so the files will be going from firewire to usb 2.0 back to firewire. Anyone think this matters? I assume it doesn't matter, but the last thing I need is to corrupt the backup footage files. The drives are all formatted mac OS extended (journaled).
Also..the GRAID is acting flakey upon startup. I booted up my G5 and powered on the drive and it did not mount. I powered everything down, swapped out the fw cable and restarted...and it then appeared on the desktop. Later I had to reboot the G5 after a software update..and the GRAID did not mount again. I put the old cable back, switched fw ports on the G5, restarted everything and it mounts! Is it about to die on me?
