Is there sth like this? A step by step, also explaining menu options like the limiter and low cut filters?
The Zoom seems to be the prefered solution for DSLR audio recordings, so I hope there is sth out there on the interweb...
Thanks for the advice guys!
For example: Is it possible to listen to the tracks separately, like a solo prefade?
Or can I record the same source to different tracks at different levels, to have a quiet backup track for sudden loud moments?
Only with the Zoom in stamina mode can you separate the 2 xlr tracks for independent levels, but that's at 16/44.1, where as in 4channel mode you get up to 24bit/48kHz.
I do the same, put a lav on my left channel and boom on my right, monitor with Sony headphones, but the lav is through the mic in on the back mini plug, boom is through XLR. It works fine. But here's where it gets annoying, in 4ch mode, playback lets you listen to your recording but the built-in/mics 2ch part is going live feed at the same time. You can turn the levels down on the internal/mic in side for playback. It's goofy. Just no way in 24bit/48kHz to have separate levels for the 2 XLRs, because it requires 4ch mode.
Having another mixer feeding the Zoom would allow the best bit/kHz, XLRs and independent channel levels, along with the built-in mics dropped to zero.
Thanks, greatly appreciated!Regarding the original question - I'm hoping to do a video tutorial with a variety of recorders (including the H4n) shortly. Will post here when it's up - looking like a three parter at the moment.
