h4n phantom power problem with condenser mic
gtxrla
I recently bought a used Zoom h4n and a new Shure sm93 condenser microphone (it came without a box though, so it could have been used or the seller was trying to save shipping costs).
The sm93 has a preamp and takes 11-53v of phantom power, the h4n provides 24 or 48v.
The h4n's internal mic and ext. mic input work good (I tried a cheap audio technica dynamic lav mic), but when I plugged in the shure sm93, there was no sound recording. I looked at both manuals and did everything exactly like it said, with both 24 and 48v, but still no sound.
When I blew into the lav mic, it registered a little on the h4n, no sound it just showed the bar moving a little on one side, but on playback there was no sound. I have the recording level set to 75.
I know these 2 work together: http://photography-on-the.net/forum/archive/index.php/t-1242588.html
I tested the xlr cable with a multimeter, and according to that it showed it was good. I will go to Best Buy to try out different cables and microphones to make sure, if they have them. I don't want to just make a claim/send back to the ebay seller if it is just a small think I am doing wrong, and waste their time and money.
Try testing another phantom powered mic in the DR40. If that doesn't work, then it might be faulty. If it works, then it's your mic.
As you do have a multimeter, check the volts at the end of the cable with it plugged in to the H4n......
Measure the DC Volts between pin 1 & 2 =? and pin 1 & 3 = ?.
? should be the same (or very close) on both measurements...
