Hey Everyone,
I recently uploaded an HD 720 24p video to Vimeo and I'm noticing a lot of stuttering. I'm wondering if tweaking the motion settings while doing the initial H.264 compression would help.
In making my quicktime for upload, I exported my sequence out of After Effects Cs3 using H.264 compression. I had my motion set to current frame rate (23.976), and had the keyframes set for every 24 frames. If I changed the settings to set the keyframes every 12 frames, would this reduce the stuttering in Vimeo? Or is the stuttering the result of the compression Vimeo applies?
My other settings were compressor quality: high, encoding: best quality, and data rate: restrict to 5000 kbits/sec.
My video is a music video with lots of quick cuts, highly saturated colors, and movement. I've seen much smoother playing videos on Vimeo, but maybe they were smoother because there was less movement?
If you're interested, you can check out the video at: http://vimeo.com/1182687
