mcsmooth
What I don't understand is why nobody seems to have been able to edit native H-264 files in Adobe CS4 smoothly with an i7. I've been following this on this forum for a year and the best advice I've gotten is to convert to the files using Pro-res or DNX-HD. I just don't get it.
For one, there are different variations of h.264. Primarily, a lot of people on here are using AVCHD off the HMC150 and 40 which uses B frames (unlike the Canon DLSRs). Bidirectional frames are much more efficient for storage, but require a lot more work to read/write making scrubbing difficult. Your format should edit a lot easier.
Also, the i7 hasn't been around that long, so figure not everyone upgraded at once (or has yet). I happened to be in need for a new machine and built one soon after the 920 came out... and what a disappointment the first release of CS4 was! They did iron out most of the bugs though.
If you haven't already, check out CS5 which decodes even smoother. I still wouldn't say it's as fast as DV if you are hopping all over the place backwards, but doable for most projects. I do still think transcoding is useful for certain applications, especially with lots of layers, each with multiple effects (at least with AVCHD from the HMC150). You can swap back for the original files at any point for final touch ups and rendering. For simple editing, I agree, it is wasteful to transcode today if you have a decent system.
Damn! I think I would have gone with a 930 and a GTX480 or maybe 24GB RAM... but I'm cheap! If 6 cores is truly 1.5 times as fast, that must be slick.i7 980x six-core 3.33 Ghz with Asus P6X58D motherboard
2 TB RAID 0
12 GB of RAM
Asus GTX285 Graphic card.
