Guidance
Vultch
I'm just about to pull the trigger on a new iMac maxed out to the hilt - i7 processor / external thunderbolt storage etc etc
Now i will install FCP studio and all my old plugins but I also wish to install FCP X & motion 5, compressor etc
Should this be a straight forward install or is there anything i need to be wary off
Create a separate partition for your FCPX stuff. You'll still be able to launch them from your main partition, but they won't muck up your file associations, Compressor's background processes, etc.
Naw, just install Final Cut Studio FIRST, then install FCP X, Motion 5, Compressor 4.
If you need to ever work in FCP 7, AND work with Motion 4 at the same time, launch Motion 4 first.
Aside from that, you won't have any problems. You just can't have two apps of the same name in the same folder. When FCP X installs, it moves all of your Final Cut Studio apps into a sub-folder called "Final Cut Studio". If you launch FCP 7, and need to round-trip to Motion 4, it'll find Motion 5 instead, UNLESS you already have Motion 4 running, then it goes directly to Motion 4.
The two versions don't share any resources, so it's not any other conflict except names and locations.
